Way you don’t add an check box or an button to print setting, where we can adjust our setting and use it as standard. In this case we will not need to adjust every time the parameters, just if we change the filament or if we need an differently adjustment.
Thanks for your support.
Thank you for the suggestion. We will keep it in mind in the future updates!
