Savonius wind turbine print question
I took a large complex model out of thingiverse  and tried to print it. I did a little research, I might have a layer misalignment problem?
It could just be adjusting the print settings differently (I am a newbie). I received the printer 2 days ago, this was my second print.
As you can see, the first 7 cm (2,75 inches) printed properly.
Can anybody help?
Thanks!
PS: I successfully printed a simpler and smaller object without any issues.
3746
Eolienne_Savonius_hélicoidale.zcode
3742
3743
3744
3745
What is your print settings you are using? it looks to me that you are using too high of a resolution drop it down to 19 and make sure you have doors on the side of your printer
Thank you, yes, it was Layer: 0.14, infill: high, material is Z-ABS. I always have the doors on the side.
I do not really mind the resolution, I will probably bump it up to the max, unless it would cause other problems.
