Seam Bug on Zsuite v0.08
I have found a problem with seams on the new zsuite version. BIG problem if the seams poit out.
I am building some models which I have printed before with zsuite v7, so the problem is with seams. I tried today the same model same settings:
The part is thin about 1.5mm thick but as you can see on the pictures it can't be a problem of thickness since the part is ok with zsuite v7
z .29
Infill : Full
Support 50°
Fan 20°
And here are the results.
Part with V7 processing, positioned to face seam in the not visible side.
[URL=http://s1242.photobucket.com/user/mmaxds/media/DSCN2984_zpsa4872072.jpg.html]DSCN2984_zpsa4872072.jpg[/URL]
With seam positioned outwards
[URL=http://s1242.photobucket.com/user/mmaxds/media/DSCN2986_zpsaf8c68ab.jpg.html]DSCN2986_zpsaf8c68ab.jpg[/URL]
NOW WITH NEW ZSUITE VERSION in both cases total fail and unusable part.
[URL=http://s1242.photobucket.com/user/mmaxds/media/DSCN2985_zps7781e010.jpg.html]DSCN2985_zps7781e010.jpg[/URL]
[URL=http://s1242.photobucket.com/user/mmaxds/media/DSCN2987_zps1d10eab0.jpg.html]DSCN2987_zps1d10eab0.jpg[/URL]
I have experienced the same problem... I am printing much smaller objects than you and using 0,14 layer. With the same settings, the quality is significantly lower with 0.0.8 version, than with 0.0.7, especially in the seams areas... I have no clue why... :-( I thought maybe it was because of the filament moisure, but it wasn't (tried new spool and tested with v7 and v8). It is even worse with 0,09 layer.
I have v2 hardware.
I will be emailing support. Let's see what can they say.
Looks to me like they have implemented a stop extrude before the end command, to try and minimize blobbing. But have over done it.
I've printed quite a few small things with 0.14mm and 0.0.8 and my seems look fine so far...
it may be geometry dependant, but no matter the geometry the seams should look better.
