More will follow
that is cool what is the box for
Wooden enclosure? Hmm…
[quote name=The6uest]Wooden enclosure? Hmm…
[/quote]
Spot on In will be finished this weekend, then I will post some production pictures and video.
There will also be some other cool features included in the box.
I’m a bit concerned about the component temps with these full enclosures. Your motherboard and power supply will run in 40 plus degrees C. Not good for a long component life IMHO.
If course you can run a stronger fan and keep the temps lower but then you loose the advantages of less warping, etc.
The other solution with doors mounted to the frame (and a top cover) can run higher build area temps with the electronics still staying cool.
I love the bamboo look, though!!!
[quote name=Andre]I’m a bit concerned about the component temps with these full enclosures. Your motherboard and power supply will run in 40 plus degrees C. Not good for a long component life IMHO.
[/quote]
I am aware and precautions have been made. If it works as planed… can’t know untill I have tried, else ill have a lovely bamboo box
excited!
