Sketch up
When I draw something in Sketchup and export to a STL file when I open it in Z Suit the size changes ether very big or very small, it seem to print fine after I re size it but if I down lode something it seem to be ok
Clark
What units did you draw in? Z-Suite is setup for metric so anything in inches comes in very small.
Yep… draw in mm or draw in inches and convert to mm on export if Sketchup will do that.
oh okay that makes sense so if I Do 6 inches and bring it in it will be 6mm thank you
I move topic to forum “3D Design Software”, it’s better pleace
[quote name=gadgetstogo]oh okay that makes sense so if I Do 6 inches and bring it in it will be 6mm thank you
[/quote]
Yeah. Or if you multiply by 25.4 it should size correctly.
