Initially wanna print a big volume, but I think need to wait for update for the firmware again to support thinner print resolution…
In the meanwhile, tried out this small print… create in SketchUp, export as STL.
Looks good. 2nd a little weird.
If you can send .stl file of second model to - support@zortrax.com then we can use it for check and tune infill
@Martin
It is one model… I will send it to you asap… once the printing is finished with the Voloroi Arch
