[Solved] Error Z-Suit after installing win 10
​I get the an error message (attached file).
After that I can load models but I cant see them.
Has anybody the same issue and maybe solution?
SOLVED:
I have a Intel GMA X4500 (gpu) and Windows 10 installed the wrong Driver. I downloaded the latest Drivers but was not able to install them. After some hours of research I found an older driver which I've had to run in compatibility mode.
If somebody has the same issue, thats the LINK to the driver ("Win7Vista_64_151717bb")
Thanks for the help!
I don't have this issue but the error message shows a version mismatch for opengl32.dll.
Search your disk for all occurrences and compare.
Maybe another app has an older / other version that is loaded already and prevents Z-Suite to work properly.
I tried to install new gpu driver but that didnt work. Then I tried to renew the opengl32.dll file but I was not able to replace the file. Then I have put the new opengl32.dll file in the Zortrax-System Directory but still doesnt work.
Dont know what to do else :(
The problem is, that you most probably have more than one opengl32.dll on you disk and another app or the system is loading the wrong one before Z-Suite is started. For this case you can figure out wich is the right one by renaming all other occurences and try each one after another. You have to restart your system every time and rename it as first thing after you logged in, maybe you even have to start in save mode.
If there is only one opengl32.dll on your disk you have to install a package with the correct one, ask Zortrax how to do this (maybe it’s in their setup but doesn’t get installed for any reason).
thank you for the advise​ but I'm not sure how I should do that.
I searched my disk for opengl32.dll and found several files but I can't rename them. Windows says I have not the rights to do that.
What you have found are the original Windows files for 32 and 64 bit subsystems.
You should leave them alone and open a support request and refer to the information you gave here.
Install/update your graphic card drivers, and check if you have installed .NET framework 4.0 or higher.
.NET Framework​ is higher and graphic card driver is on latest Version.
Here is the detaild error:
************** Ausnahmetext **************
System.EntryPointNotFoundException: Der Einstiegspunkt “glGenBuffers” wurde nicht in der DLL “opengl32.dll” gefunden.
   bei OpenTK.Graphics.OpenGL.GL.Core.GenBuffers(Int32 n, UInt32* buffers)
   bei OpenTK.Graphics.OpenGL.GL.GenBuffers(Int32 n, UInt32 buffers)
   bei A.
.(Int32 , Vector3 , Boolean , Nullable`1 , Boolean ) in File153:Zeile 641.
   bei A…() in File115:Zeile 104.
   bei A…(Int32 , Int32 , Double , Double ) in File115:Zeile 83.
   bei A…() in File137:Zeile 1159.
   bei A…(Boolean , Boolean , Boolean , Boolean ) in File137:Zeile 1248.
   bei A…()
   bei System.Windows.Forms.Timer.OnTick(EventArgs e)
   bei System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
   bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
mscorlib
    Assembly-Version: 4.0.0.0.
    Win32-Version: 4.6.106.0 built by: NETFXREL2STAGE.
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll.
Z-Suite
    Assembly-Version: 1.3.0.0.
    Win32-Version: 1.3.0.0.
    CodeBase: file:///C:/Zortrax/Z-Suite.exe.
System
    Win32-Version: 4.6.79.0 built by: NETFXREL2.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
Z-Suite&
    Assembly-Version: 1.0.0.0.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System.Drawing
    Win32-Version: 4.6.93.0 built by: NETFXREL2STAGE.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
Zortrax.View
Zortrax.View&
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
EO.WebBrowser
    Assembly-Version: 15.2.65.0.
    Win32-Version: 15.2.65.0.
    CodeBase: file:///C:/Zortrax/EO.WebBrowser.DLL.
OpenTK
Zortrax.Data
Zortrax.Data&
Zortrax.GCode
Zortrax.GCode&
OpenTK.GLControl
mscorlib.resources
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
EO.Base
    CodeBase: file:///C:/Zortrax/EO.Base.DLL.
Microsoft.WindowsAPICodePack.Shell
    Assembly-Version: 1.1.0.0.
EO.WebEngine
    CodeBase: file:///C:/Zortrax/EO.WebEngine.DLL.
System.Windows.Forms.resources
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration>
    <system.windows.forms jitDebugging=“true” />
</configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
