Pictures of the new engine , still waiting for parts and still have to print the seals , this should be totally done before new years ( I hope hahaha) , believe it or not this engine can be used multiple things other than just being for propulsion , has no moving parts , and with some small add on's becomes stealth under water , already started on the gas exchange and hydrogen fuel cell adapter (may also add a turbine for when it's not in stealth lol
the link below is how this engine works , I'v made some adjustments and other considerations that improves the output and will be adding some extra's to make it more efficient , just finished designing an add on to it that can spin a turbine to add up to 35% more power output , it will when finished also collect the gases and use a hydrogen fuel cell to help power efficiency : https://en.wikipedia.org/wiki/Magnetohydrodynamic_drive
