Error in the STL-file. Same with earlier versions of the Z-Suite. Maybe it is only this file, but this works with Voxelizer.
Can you send me the .stl file, please? Did you set some specifc settings?
Hello, it works after exporting to SAT (Acis) and read back and automatic repair. I suppose that Z-Suite uses some kind of automatic repairing of the STL-files? In Voxelixer there is the same but it is not default. So it is not a bug.
Hello, thank you for the update. Yes, Z-SUITE provides auto-repair function.
But if I don´t want automatic repair?
Use menu Model->Import without repairing
Thank you! I need to test this. So it was user error…
I tested and it works. I don´t understand why this automatic repair is default?
