The Cura software places the supports perfectly, as I wish !
With Z-Suite 2,6,2, it is impossible : the supports are visible on the face which must not receive it !It’s a visible side.
I do not want to print in another direction because this face is hyperbolic and must be perfect.(this face can not be printed horizontally because the layers are too visible: staircase)
I tried with the "automatic" supports and also by creating myself the supports (support surface, point or edge): the result is always the same
With Z-Suite 2,6,2, it is impossible : the supports are visible on the face which must not receive it ! It’s a visible side.
I do not want to print in another direction because this face is hyperbolic and must be perfect. (this face can not be printed horizontally because the layers are too visible: staircase)
Is there a solution ?
It works correctly when choosing the Legacy Support.
