I thought it would be a good thing if supports which are touching the lower model parts could be chosen with one contact point instead of three.
A setting like “Contact points bottom” that can be chosen between 1-3.
Hi Skywolf!
Could you please explain in detail what you mean by that? And for which printer.
A simple drawing would be helpful.
Kind regards,
Marcin
Hi Marcin,
First off thanks for caring about this.
What I mean is that currently supports that originate from the bottom of the model are always tripods.
(Those not originating from the build plate are 3-legged)
A good feature would be if it was customizeable to have 1,2 or 3 legs.
This would be for the Zortrax Inkspire or similar resin printers
