Hey,
I have to print watertight parts with the inventure.
I have the problem that the surfaces under the water-soluble support only have one full layer.
The first time I noticed this was with a small defect in the print of one of these layers, which resulted in a small hole where you could see the infill.
The Models will be under pressure and that is a problem.
I increased the bottom surface layer count to 6, but nothing changes in the preview nor in the printed model itself. Tried 150% density too, no changes
Am I doing something wrong?
I have the feeling that the software is not designed for mechanical applications. Unfortunately…
