Switch from Ultrat to ABS, just swap filament?
What considerations / procedures  need to be taken when switching from z-ABS to z-Ultrat?
Remove Z-ABS using the unload command> get Z-UltraT spool> Load Z-UltraT spool on back of printer> Load filament through the feed tube into print head> use Load command to prime filament> Slice new model in Z-Suite for UltraT> Put model on SD card> Use print function.
Thanks!
No different from switching out to a new z-ABS spool then :)
My OLD printer had some major hoops to jump through between switching certain filament types.... I am glad that is not the case here.
