Table's power cable's length is short.
Dear Zortrax Team and Owner of M200
Pls… Check…
I found some problems.
Table have 2 lines.
maybe I think one is for sensor.
another is power cable for hot bed.
Table’s power cable’s(for hot bed cable) length is short than sensor’s cable.
Sensor’s cable is have not problem.
But … If I move top by manual… Table.
Maybe This cable is very tight.
http://www.flickr.com/photos/114662285@N04/11988804705/
http://www.flickr.com/photos/114662285@N04/11989103283/
Have a nice day…
You may want to take a photo of it because it is difficult to understand what you are saying. The sensor cable comes off of the heating bed cable and it is more than long enough on my printer. Make sure you run the cable through the inside of the bed support and not outside or behind it.
[quote name=The6uest]You may want to take a photo of it because it is difficult to understand what you are saying. The sensor cable comes off of the heating bed cable and it is more than long enough on my printer. Make sure you run the cable through the inside of the bed support and not outside or behind it.
[/quote]
Sorry…
I made link for pictures…
Pls check… your machine and reply…
Have a nice day…
Yep… That looks short…
Does it have 2 cables for the bed? Mine has one with both connectors in it.
@lasercraft
Length of cable is correct just too much of cable is rolled up at PCB side, we will send to your PM pictures with manual how to solve this problem.
[quote name=The6uest]Does it have 2 cables for the bed? Mine has one with both connectors in it.
[/quote]
Never mind, mine has 2 cables too. :slight_smile: They just tie in to the same connector.
Carry on…
