Hi, I was wondering if the temperature the hotend is reached when going to load or unload filament is set based on previous temperature used?
I’m just thinking if I can he from a low temp filament such as PLA and go to a much hotter filament such as Nylon, wether the hotend is reaching a suitable temperature for loading the filamen.
I have some high temp filaments that have not loaded correctly using the load filament process and mean I have to clean out the hobbed gear unless I run a print at the correct temp and use that to load the filament.
