Hi I´m new user M200 printer. I feel like a Little kid with a new toy´s. I wanted to know about the temperature´s print bed. We can control the temperature of the bed fron Z-Suite?.
Which is the temeprature bed are used for the diferent materials, like z-abs and z-abs hits?
Hello, all these parameters are set to each material and can't be changed. You select ABS, then a given set of parameters, or profile, such as bed temp., nozzle temp. etc are used in the firmware. Very easy, select material, infill etc, start printing and that`s all!
As stated above, you cant change temperature by your own. Every profile (ABS, ULTRAT etc) has its own settings [temp, speed etc] prepared to achieve best print results. You can check it using Thermometer with the probe but since you are unable to change it, it wont be very useful knowledge.
Marcin, accidentally, I printed the abs material with z-setting ultrat,
printing came out very well,
it would be useful to have the temperature values with the different settings ?
thanks
I'm not exactly sure if you are asking about changing temperatures by yourself? I believe that could be useful, but since we've closed ecosystem and we are not developing open source Software it wont happen, ever.
Temperatures of the hotend between ABS and ULTRAT are not that high, so most of the prints will come well enough but its much more values that are assigned to profiles (table temperature, speed, feeding etc).
