Over a year of printing with M200, prints have been coming out great and I am using the same materials mostly PLA+. Suddenly I cannot print at temperatures which I have been using so far (220 which is on a high end of recomended). The material loads without a problem, when I do 2nd load material it comes out perfect, continuous that is most likely because loading is set to higher temp. Once I go ‘print’ the model the material; gets stuck right away. I have experimented with temp and when set to higher it works but it is too much for the material so the surfaces get streaky. I have 3 different hot ends and multiple nozzles, including brand new. I tried printing @ 235 and the material got stuck right at the beginning, then @ 250 (which way too much for PLA) it was not working till 265. I cleaned nozzles, hotted and feeding path.
Hi, @TKAstudio.
When was the last time you replaced extruder cable or heater&thermocouple?
Have you tried printing with brand new hotend (whole, not just nozzle)?
The issue may be caused by underheating.
Do you have a multimeter, so we could check which part causes the problem?
thanks, I have 1 hotend for ABS which I almost never use and 2 for PLA+ which I have been using a lot since I bought the printer 1.5 year ago, sometimes 24/7. I ordered another hotend and I have multimeter, let me know what should I do. I also noticed that the PTFE tube is slightly damaged, the material goes through with out a problem but I run a small rod inside I can feel the inner walls are not smooth. I ordered new tubes too.
It’s good to regularly replace hotend, as PTFE tube wear can lead to quality deterioration and extrusion problems.
As for the heater, please check its resistance as in the picture below and let me know the value.
should the heater be hot? or just printer ON?
The printer should be turned off and at room temperature. You can also check thermocouple’s resistance (black and red cables).
I set my multimeter @ 200M and I am getting somwhere between 95 and 105, the number keeps moving up and down. Its for both red and black and black and black.
Hey there! Please, set your multimeter to 200 Ohms (like in the picture) and measure it again. Remember to turn off the printer.
so for black and black I have 13.1 or so and red and black is about 2.7, going from 2.5 to 3.1.
Thank you for the information. Resistance on the heater is too low and indicates that its underheating. In that case, you need to replace heater&thermocouple. If you purchased your printer from Reseller, contact them directly. If you purchased it directly from us, complete the support form.
thanks, I already ordered it from reseller in US. Also, what is correct resistance?
The correct resistance should be 15-16 Ω, lower value means that there is an underheating issue (and higher - overheating).
OK, so I have replaced both the thermocouple and hotend (before I replaced the hotend I tested the old one, indeed it was no good). I measured the resistance and it topped out @ 14.4 ohms. I made a test print with settings before the trouble started and it came out just right. But the temperature I used was higher than recomended for PLA+ (225 max) @ 235, I tried going lower and the feeder would skip here and there printing “dashed line”. After that I would set it to load material which of course because of higher temp it would come back to normal and than print @ 235 just fine. For transparent PLA+ I have go above 240. This has been the case since the day one so I thought it was normal. May be not?
Please, keep in mind, that changes in material’s composition can also influence printing temperatures.
Have you tried printing Z-ABS? Does it load and print properly?
Hey, I decided to bump the subject because I belive facing similar problem.
For couple of weeks we face issue that was described here as “engine stuttering”
h-ttps://forum.zortrax.com/t/extruder-stuttering-when-printing-raft/3051/48 (https://www.youtube.com/watch?v=uk2MYzIQFAo&ab_channel=juliadeetruchsess)
We have changed the nozzle, gear (and later whole extruder motor) checked connection of wires, yet we didn’t manage to solve problem so far.
This “stuttering” occurs during loading material, printing, and in general always when filament is going through the nozzle. Without nozzle engine is not stuttering.
However what we managed to notice is that “stuttering” happens when engine is under heavy load.
Thus now we expect that heater is not working properly:
→ not warming to given temperature → causing filament to not be runny enough → extruder motor is not strong enough to rotate and move filament forward
We have warmed the heater by built in program (in printer options I mean) and the software shows temperature to be 240 degrees. We have tried to measure temperature in different spots of nozzle and hotend and heater itself with infrared thermometer. Each time getting temperature lower by more than 30 degrees.
Resistance of heater varies between 15,8-16,2 and resistance of thermocouple 3,9-4.
Is thermocouple resistant correct?
Moreover, we have noticed electrical breakdown on thermocouple (I believe I am using correct term) - electricity is passing from wire to metal head of thermocouple. Can it be a cause to show incorrect values of temperature and lead to to low temperature on heater?
Or maybe we are totally wrong and something else is causing stuttering of our extruder motor?
Hello mesxwi,
Which printer do you have?
Could you please send me a video of your problem?
It could be a problem with extruder cable, hotend or the thermocouple & heater.
When was the last time you replaced the hotend and thermocouple & heater?
Hey Pawel, thank you for reply.
Writting so much just to skip such important part as printer type
- Zortrax M200 Plus
Heater and thermocouple resistance: (https://youtu.be/041FD4NczEE)
Problem with extruding: https://youtu.be/pfzFEPTT3Ys
We have around 600 hours of printing with this printer. Hotend, thermocouple and heater were not changed in this time.
Also we went through this process already (Troubleshooting: Extrusion Problems in 3D Printers | Zortrax Support Center) with no success.
Hello mesxwi
I’m facing a similar problem. Did the replacement help?
Did you try measuring resistances on the new part? I also have a short-circuit between the thermocouple and its pins and I wonder if it’s normal.
I replaced hotend and thermocouple and it works fine so far (almost 3 years).
I was trying to print on old thermocouple and new hotend and it was also working. So seems like hotend was the one to blame.
