Hi.
If I put additional exposure time for support, the time is added to the total time, but in fact, it is not applied by the machine.
Best regards.
Hi.
Best regards.
Hi Marta.
The file is 74Mo…so i can’t upload it
I use external resin, light supports on which I have augmented the diameter due to “only from raft” bug. I put 20s of normal exposure time and 25s of additional support time (to test).
When i put the file in the machine i can see the 20s and the 25s in the file parameters, and the total time seems to have been correctly calculated.
I started the machine and I could see that only the normal exposure time is applied: about 20s between layers instead of about 45s.
Maybe it is a problem of firmware in the machine…
Thank you for the information. I’ve sent you a PM, please, check your inbox.
