I cant seem to get the printer to pause when I set it up in Z suits? i insert it but the printer never stops?
what am I doing wrong?
Hi … i have this same problem with "insert" function in Z-Suite :(
We'll check it on Monday.
Pause function by pushed the button for 10sec.
Same here.. Just tried it.. That looks good Pioo!!!
Maybe I'm doing something wrong. How to do it correctly in Z-Suite ?
You are doing nothing wrong.. I don't thing any of us can get it working..
@Rafał .. where in Pause function in Z-Suite for MAC OS X?
For information :
<a class="" href="http://forum.zortrax.com/#" title="Insert member's name into Shout">@</a> <a class="" href="http://forum.zortrax.com/index.php?/user/4-rafal-tomasiak/" title=""><span><span style="color:#008000;font-weight:bold;">Rafal Tomasiak</span></span></a>
<span style="font-size:12px;color:rgb(119,119,119);">(12 July 2014 - 07:57 PM)</span><span>New ZSuite for MAC will be ready in next week, all GUI will be new</span>
<span style="font-size:12px;color:rgb(119,119,119);">(12 July 2014 - 07:58 PM)</span><span>And new function will be added.</span>
Ok … i know where is problem.
Problem is Z-Suite.
You can find file (Z-code) with pause test:
IT WORKS!!! … but not on my Z-Suite :(
https://dl.dropboxusercontent.com/u/19671723/Zortrax/test%20zmiana%20koloru.zcode
@Rafał ... @nizzy ?? any news?
I'm having the same problem. Any solution?
You must use "Save As" then select the SD card as destination folder. Can't use "Save to SD-Card" For some reason it just doesn't work that way. You can double check it by opening the Z-code you saved in Z-Suite from the card. It should show the red line "pause point" Hope that helps.
thank you Kyle, that worked, did you jest figure that out or did Zortrax come up with it what ever I am a happy camper
Someone figured it out.. I just verified and posted.. :D
Thank you Kyle!
Does the pause occur before the "red" layer is laid down or after the "red" layer has been laid down?
