There has to be something wrong with the material endstop - please fill in Support form: https://support.zortrax.com/support-form/
As for now, you can simply ignore the material endstop from the menu. There won’t be any pauses then.
hi giufini
I tried to reproduce the issue on my machine but I couldn't. It is working flawlessly.
However it is brand new, so maybe it will happen after a few hours of printing. I will be careful about this issue.
Same here, the proposed solution of "ignoring the endstop detection" is a joke. No user pays this money for a shitty printer that will have endstop failures even a Cr-10 detection system works better.
We have been doing a job with an almost empy spool that needed to be resumed like 7 times....
A printer with this functionality is useless if the endstop detects a false signal, It's very simple because it's mechanical just like the one from Z-temp but more shitty zortrax version.
We also have issues with bed adhesion from day one, if this printer keeps failing like this you will not sell a single one through us and we will fill a claim to return this useless product. It's not acceptable Zortrax, you demand too much from your resellers and always want to push harder on sales targets but your products are not what you advertise, Inventure printers don't work flawlessly, Hepa covers on backorder, Z suite print quality is not improved with new releases, bugs, issues on firmware, etc etc
Probably you have a problem with the filament endstop too. Please contact me via PM, so we could sort it out.
I had the same problem, luckyly when I removed the filament, i extracted at the same time a little ring of dust, and never again had the problem…I believe it is the dust covering some kind of sensor that activates the alert.
Same problem here with our 2x M200 PLUS.
