Hi everyone,
I'm new here and I just started to use my zortrax today. And I do have an auto calibration problem.
Can someone explain to me how the auto calibration works. And what's the tolerance between the 4points ABCD (max deviation allowable 0.1 or 0.05...?) when the extruder head travels to all these points and does some measuring routine. I believe they do a torque related measuring, but I can be wrong.
I also see that the leveling procedure is in fact strange. You only need 3 points to define a plane in space. But I suppose they do this to be sure that the bed is flat.
Because that's what I see now one corner does have a bigger deviation then the others.
So my print bed is not flat. So that's why i'm asking this. I suppose it's within specified tolerance and zortrax did check this before sending me the printer.
So can someone give me some insights about tolerances they use.
But until now I really like the setup of the printer it's really well designed (for a cheap printer) but the connector for the heated bed is at least to say small.
The perforated bed is also a nice feature. I think I will enjoy the learning proces.
