I am trying to find good settings for printing transparent ABS. I know, it will never be glass-clear, but i just am looking for the best result.
So far, i have tried changing temperatures, the specs say max 230, but at that temp the nozzle seems to be clogging up regularly.
The tests i ran so far (all using the abs based filament):
nozzle temp/bed temp/print speed/extruder flow ratio
250/60/0%/0%
250/60/-5%/0%
250/60/-5%/+5%
250/60/-10%/0%
240/60/0%/0%
240/60/-5%/0%
(and i quit 240, because the nozzle seemed to get clogged also at that temp).
They all seem to give about the same outcome funny enough. I did notice the difference in top/bottom layer compared to the sides: the sides are pretty clear with 250/60/0/0, but the top and bottom layers are not so much.
I did notice that the topmost 2 layers of the rafting are pretty good!
So now i am looking for the correct settings, based on the ABS filament to get the same result as the rafting has for the top and bottom layer..
i think if i get that right, the print should be the best i can get it..
So does anybody know the correct settings to get the same results as the 2 top layers of the rafting?
I am using the lates firmware and z-suite for it.
