Tree Frog
This frog ist printed with 0,14 mm layer thickness
I printed them one day before the new Z-Suite 0.08 released... :rolleyes:
Hope you like it! :)
http://www.thingiverse.com/make:86517
168
169
167
166
165
164
Looks good.. I think if you up the fan to 80 or 100 the belly will look better. I have printed many of these..
Kyle, thanks for your advice. I will try with more fan.
I printed mine with .140, 10 degrees support, 100% fan
Ok, I printed mine without support.
I will try different settings and 0.09mm layer next week.
There is enough "TreeFrog" Green material in stock. :D
Well to be honest, 10 degree support only puts it in under the top of front legs where they connect to the body. I'm sure it would be fine with no support. Just full fan.
