I've also had support issues with the latest release of z-suite with ultrat. If you select a 20 degree threshold for 90um support is generated on some parts, with the same threshold for 140um no support is generated so I think it is a bug.
Regards
Matt
Yes, most likely it is a bug. First thing to do is turning on/off Smart Bridges, it often helps.
However, you can send me STLs (could be through PM) and desired settings so I can take a look at it.
