I got a problem with my printing. The printing is sometimes not finished for the same ZCODE file. It stops at 90% or so. But on the screen, the process is marked as 100%. I used a USB disk to transfer the file.
The firmware version was 2.6.6, and the Z-SUITE is 2.32.0.
Thanks for any suggestions.
Best regards. v2 p1.1.zcodex2 (708.6 KB)
I checked the link. Since the printing process was marked as 100%, I did not list ‘material runs out’ as a reason. (In my case, the material did use up.) https://spport.zortrax.com/problems-with-incomplete-prints/
I have not encountered the same problem in other models.
If you have never printed the model before and it is an error for a new project, I suggest to rotate the model a little and re-slice it.
It happened to me some years ago a similar problem, maybe an error in the slicing process and I solved this way.
For the problem with separating model from raft you can try performing the autocallibration first, and then try increasing the first layer gap a bit if that didn’t help
It also looks like raft could be printed too close to the platform as well if it’s hard to take it off the build plate - for that you can try increasing the platform-raft gap.
Thanks! These suggestions do solve my problem of hard-moving raft.
But is it also the root of unfinished printing? Even though the printing process is marked as 100% on the screen.
Here is the origin .stl file. Because the printer tends to go wrong under long printing time, I have to split the model into 8 pieces (using the ‘split model function’ in Z-suite.) This failed print is the left lower corner. test v2.stl (1.7 MB)
