Useful things for the printer itself (In my mind)
Here I will show things for the printer itself what I have designed and printed.
I think these things are very helpfull.....
Fan for the extruder gear (blows air through a channel to the extruder gear. Connected in parallel to the upper fan) - reduces the softening of the filament at high room temps and extruder temps
2066
Spool stand with bearings - reduces drag.
2068
Toolholder and filament waste bin
2071
IP Cam with holder
2072
Thermometer with holder
2073
Ikea Zortrax shelf & enclosure
2069
Regards Clemens
Very helpfull indeed, you did a nice with all these accessoires. I pesonally like the toolholder, would you be willing to you share the design ?
Hi Clemens,
Is it possible to share your 3d models on this forum (STL files) especially the support for the webcam. :)
Thanks !
Dirk
Hi Clemens,
Thanks !
Dirk
Use "more reply options" button, or use Thingiverse.. Then just share the link..
Hello Joeri and Samba,
Sorry for the late answer.
Here is the stl for the IP Cam Holder. Print it with the big flat surface down.
2078
IP Cam Holder Ver3.stl
And here is the stl for the toolholder/filament waste bin. You should print the holder and the box upside down (and the cap with the bigger surface down). You can print the box and the cap the same time.
2079
WasteboxHolderVer2.stl
Regards,
Clemens
Thank you Clemens !
Hi Clemens,
Could you also share your extruder fan mount? I'd like to make one.
Thanks,
Shen
here is it....
Turn it 180° in  Zsuite.
Regards,
Clemens
It looks great, thanks Clemens
