Using Z-abs with other printers
Hi
I was wondering if someone else has tried to use the Z-abs with other printers, I'm trying to use it but seems to be a really hard to use material. What could be the recommended settings? specially nozzle and bed temps?
Guessing bed at 86 Celsius and extruder at 270-280 Celsius.
Works nice on pp3d printers.
Z-ABS and UltraT both work well on my Up/Afinia at full temperature (260-270C).
Julia, The mini has a bed temp of 60 °C right?
50C  but should print Z-ABS fine. Actually does, as I have done it.
Never used a Mini, so I don't know. The original Up/Afinia is 100C I believe.
They work flawlessly even with Z-ULTRAT I have tried both on Mini.
Hey,
Can anyone tell me if it is possible to use 3mm ABS filament with the Zortrax M200? Does it have to be 1.75MM?
has anyone tried this before?
thanks!
I'm thinking no.. It must be 1.75mm
Its not possible to use 3.00mm without upgrading extruder completely. Currently there is no option like that!
