Uv cover slider mech inkspire
hi all
new to this forum
had my inkspire a couple of months now and there is something missing with the machine…in my estimation… why did zortrax not build a hepco slider mech to slide /lift the uv cover up and down manually … all it would need is same hepco to reverse of z axis arm and suitable bracket bolted to uv cover?? with a gravity hold stop to hold open …simple
I’m going to buy a second uv cover and print an extra base for the machine to sit in and to carry the hepco stem and build my own … im fed up of bashing the uv cover on the body of the machine and covering it in sticky finger prints
a sliding uv cover would eliminate both these problems?
what do you think?
