Tecdia has released a 0.1 mm diameter nozzle.
I would like to try this nozzle with the Zortrax M200 Plus.
However, the Z-Suite only supports the nozzle up to 0.3 mm.
Could you modify the software to allow the nozzle to be set to a desired diameter?
Unfortunately, it is impossible to modify the software tot support 0.1 mm nozzle. Most of all, the profile would need to be thoroughly tested before the release.
