Has the zcodex2 been prepared in Z-SUITE 3.0 BETA? Is it a standard profile of Z-ASA or a modified one from the external materials section?
Please send me the file.
can I also have an .stl file, please? Since you are using an external ASA - I would like to run a test print using Z-ASA Pro. In general, this part of the model looks overheated, which could have been intensified by the infill type (solid) and 0% fan.
When was the last time you replaced consumable parts such as the hotend or heater&thermocouple? If one of these parts is worn-out, this could have affected the print too.
Kyc_spacer.stl (34.2 KB)
I’d wager it may as well go well a few next times. It’s just something that pops up from time to time. There’s not much I can do about cooling, it I use the fan I’m going to have highly warped bottom surface and likely the print will pop up during printing. I have Z-ASA-pro, newly purchased for testing.
Sadly I can’t run the print currently due to This
By the way - how often do you suggest X/Y axis motor replacement? It seems both of mine gained some resistance on torque.
thank you for the file. I will print it so we can compare the results.
As for the XY motors - rarely do they fail, hence we do not provide their approximate lifespan. However, if the pulleys rotate with resistance once turned manually - then yes, the motor might need replacement.
