I've seen this in a couple models, but it only happens at .19 and .39 layer height. This has been printed on other printers fine, so it isn't a problem with the model.
The surface is stepped during printing too, so it isn't just in the visual rendering. And the model is sitting flat.
This is the model loaded.
Here it is sliced at 0.14. No problems.
Here sliced at 0.19 you can see the stepped surface. I get the same results at 0.39.
Check your angle. Maybe the part is not 100% flat/horizontal. When you have a very slight angle on a flat surface you sometimes see these single steps. And the step can shift its position depending on the resolution setting.
Nope, as mentioned above, the part is perfectly flat. I can double check by looking from under the virtual bed. The whole area is dark, meaning the part is sitting flat.
Plus that doesn't explain why at higher resolutions the step is not present. If it was there it would show in every layer height setting.
I've attached the file. You will need to rotate it 90 degrees to sit flat.
Yea same problem for me. I opened file in solidworks and converted it and back to stl again and then it is ok in z-suite too.
Thanks Trhuster. That is strange as the file was originally created in Inventor, and I've never seen a problem like this before. I've also seen it a number of times with customers parts. But only at .19 and .39 ( Not that I print with .39, just noticed it).
Slicer is ok, some files from internet need to be fixed. You should check broken files with repair tool designed to detect and repair errors in meshes.
It happens because you can print multiples oflayer thickness only. Half or third of a layer cannot be printed for example.
For instance part is 10mm high and resolution is set to 0.39mm. Part contains 25 layers. 10mm = 25 * 0.39mm + 0.25mm.
Slicer has to do something with that remainder after division which in this case is 0.25mm. If remainder is higher than 0.195mm aka (0.39mm / 2) new layer is created. If it is lower than 0.195mm aka (0.39mm / 2) nothing happens. In this case new layer is created.
It happens because you can print multiples of layer thickness only. Half or third of a layer cannot be printed for example.
I have similar problems, but for me solution is... rotate part :). Rotation depends from 3d model. For example for some parts I have good results with -270 in x-axis and with others +90 in x-axis.
This part:
When I want print this in horizontal position then glitch shows for +90 in x-axis:
But it's not appear when i give -270 in x-axis:
It's still same part place and direction :D It looks like it's bug in slicer.
Rafal then tell me why 360 degree rotation of part in other direction remove this model "bug"?
If you doing rotate in Z-Suite then every triangle coordinate is recalculated to new position and rounded to not so crazy floating long values as in original - I didn’t looked at slicing engine since year but so far as I remember floating numbers problem and flat triangles can happen and it is mostly bad job of software which saved .stl
YosemiteSam showed example of part re-saved with Netfabb and woking correctly afer this - nothing more to say.
