What are the print setting for this .zcode file
Is it possible you have a program that i can drop a .zcode file in which can read all the setting temp, layer height, retraction, etc, etc.
I somehow reset my z-suite settings for an external material i use. It took me some time to tweak with printing and i dont want to go through the “R&D” again.
Here is a link to a .zcode file which has the setting: 14 20 UNC Cutting Jig1.zcode - Google Drive
Thanks in advance
all setting are saved in the txt file of same .zcode name in same directory, if you have enabled the option to export that file
otherwise nobody could tell
Yes, it was me who suggested this several years ago and was implemented.
