Hello, I wanna try out the new “no raft” option.
What is a good brim setting to start with?
Hi, @Weregeek.
If your model is small without many protruding elements, a standard brim settings (3 pcs of Brim Width, 0 mm Brim Offset) should work fine.
If you find that brim is too tightly attached to the model, you can increase the Offset (it will create a gap between the model and brim).
In case you want to print larger model with parts that may warp during printing, you can increase Brim Width.
