peconi
April 2, 2015, 4:25pm
Hello friends,
Which material (Z-ABS, Z-ULTRAT or Z-HIPS) would you suggest I use to print the Prusa i3 Rework parts?
- http://reprap.org/wiki/Prusa_i3_Rework_Bill_of_materials
Since these are parts for holding the 3D printer parts in place, as well as some gears, quality and strength matter the most.
Thanks!
LabRat
April 2, 2015, 5:26pm
Since you're going for stiffness, I'd say UltraT or HIPS. I haven't used it, but I've seen posts that HIPS is a pain for support removal, so maybe just UltraT.
voudas
April 2, 2015, 7:21pm
5
only specific parts get stressed and these only can be made from sth stiffer than z-abs, IMHO for all the other parts using anything else rather than Z-ABS is overkill...
Hello friends,
Thanks!
For operational parts I would do ZUltrat.. I believe it has better heat resistance.
I know ZHips has great tensile strength as I printed shelf clips and it is holding a shelf with 20 lbs and no bending.
You also get less shrinkage and warping with the ZUltrat so if hey need to be precise it is a must.
