axel
I use the white z-abs to print littles lampshades because the light that is diffused is very beautiful and soft (wall thickness of 1.2mm).
Does the white Z-hips also diffuse light with thin walls?
I would like to print large lampshades and not have any shrinkage or deformations.
The sample on the left is Z-ABS and on the right is Z-Hips
Both were printed the same thickness and I can't tell the difference in the translucency when I shine a torch through them
3984
axel
Thank you very much Carbon 1 for the precise and very explicit answer !
