I use a pc with windows 7 and Z-Suite 2,7,3
I would like to update to windows 10
Does Z-Suite 2.7.3 work well under w10 ?
Should i have a particular pc configuration ?
Do I need to reinstall other software to run Z-Suite ?
You may find Z-Suite 2 minimum system requirements here: https://support.zortrax.com/z-suite-2-manual/
There is no need to reinstall other software to run Z-Suite 2 successfully (.NET Framework or Visual C++ are exceptions, but in most cases reinstalling these is not necessary).
