Hi all,
Photos below are of my winged victory print. After I print the 20mm test cube I though I go for it and print a complex model to see how zortrax handle it. After about 24 h it turn out great
Hi all,
Very cool!!!
Yep, looks good! Did you print with default 30 deg support?
z axis resolutions is?
Very impressive! It seem like this printer has a very good extruder setup, no slipping no nothing!
@The6uest yeah it was print with the default 30 deg support. It has tonne of support for the wing and the clothing. Should of print it upside down, save abit of material for support.
How is the brain cube print you did. Did it work well ? Was going to print one out
[quote name=ticanaus]How is the brain cube print you did. Did it work well ? Was going to print one out
[/quote]
It came out pretty well but not all of the gears would turn. I would wait for a software update before you try to print one. Also I think printing it on its side would be better than on the base as I did.
