Hello again :(
I have big problems printing parts thats comes out in the right dimensions. I have attached the files to this thread. Maybe anyone can help me.
I am really frustated now, and i dont know what to do.
The dimensions differs up to 0,7mm....
The wall on this model should have 1,5mm --> printed out 1,8mm --> difference 0,3mm
The inner wall dimension should have 107,5x67mm --> printed out 106,75x66,35mm --> difference 0,75mm
The outer wall dimension should have 110,5x70mm --> printed out 110,37x70mm --> THATS OK! I can live with that.
The complete height of the model should have 9mm --> printed out 9,23mm -- difference 0,23mm
To be honest... is that normal???
I think its a "wall slice" problem of the software. How thick should a wall be at least?
Because if the wall with 1,5mm were right, the inner dimension should be right too?!?!?
Print settings: Z-Ultrat at 0,14mm --> All settings are default (resettet before printing)
Software: Z-Suite 1.6.1
A cube with 20x20x20 is printed exact.
Can anyone look at my files and give me advice what i can do?
Do the Z-Suite version do have an effect to the dimensions?
Greets Felix
