I am very impressed with the print quality using the new Z-ASA-Pro filament.
I have done some acetone polishing of some parts printed in Z-ASA-Pro and it works well.
I did some strength tests and has similar strength to the Z-Ultrat only very slightly stronger.4408
axel
July 20, 2017, 12:30pm
Thanks for the pictures !
Is it possible to stick (glue) objects together with acetone ?
ByteC
July 21, 2017, 6:24am
I did some strength tests and has similar strength to the Z-Ultrat only very slightly stronger.IMG_3005.JPG IMG_3010.JPG IMG_3008.JPG
Desperately waiting for that material Carbon1 :) We're using UV curing systems to dry ink on products, and I made some cases with standard ABS. Will see how the new ASA material acts when being constantly hit by 8W UV-C Leds over a longer period of time.
I have not had the need to glue the Z-ASA Pro as yet but by the way it acetone polished I believe it will also glue with acetone.
