I believe coating the zglass piece with XTC-3D from smooth on will give you the effect you’re looking for.
Plus doing she’ll with no infill helps majorly
You have used this product on z-glass?
He manages to give transparency to the piece?
Z-Glass is transparent (look at Z-Glass filament), but layer by layer printing makes it less transparent, because melted layers don't join in ideal flat surface;
the thicker layer option you choose, the better effect of transparency is because more intact space there is;
... or they improve printing of such material technology :)
This link which discusses making Tauman T-glase transparent might help. I haven't tried it yet on Z-Glass so can't comment on whether or not it works.
http://taulman3d.com/t-glase-optics.html
Mike
Mike
Wow those results are impressive; they really look like standard parts! I don’t have any z glass, by someone that does should definitely try this. ![]()
ok i will try in a while :)
well i am not satisfied...
i tried 2 different resins on o single shell cylinder.
top is xtc-3d and bottom is Z-poxy pt39 (love the irony!). middle is untreated. both resins were single passed.
1667
there is a hint of better clarity but it is not actually any clearer.
ps. while preparing the test i wished i had:
1. a spiral "vase" mode equivalent in zsuite to avoid the zipper line in such a design
2. "0" as a choice at the surface layer setting, so as to set 0 top layers and print the cylinder as mesh (not as shell) and end up with a glass
3. a 0.29 z-glass profile for better result in this particular aspect
EDIT
**** my bad, i forgot coating the inside... (ty LabRat!)
let's see now... (very fast try, i;m gonna do a proper retest for better pictures)
1668
it works like a charm :D
Did you coat the inside as well?
I thought there might be some issues due to the chopped glass fibers, but I was hoping.
i wanna kiss you! (ok not really :p )
i just updated my last post :)
EDIT
Wow - that looks a lot better!
Huzaah!! That looks awesome! Looks like I’m going to have have glass, v2 hotend, and some xtc heading my way soon. ![]()
EDIT
i used shell (x1) option. last photo has resin on both outside and inside surfaces, 1st has outside only.
