I’m new to this forum as I am to 3D printing. Got my m200 just after Christmas and have been experimenting with different models, filaments and settings. The picture below shows the same STL printed in Z-ULTRAT on the left and Z-HIPS on the right. Print specs below.
Z-ULTRAT
0.09 mm
full infill
normal speed
30% support
Z-HIPS
0.14 mm
full infill
normal speed
20% support
The actual print is 38 mm in diameter and the model has some rather fine details which did not translate fully to either print. Z-ULTRAT did achieve higher quality (I suspect because of the smaller layer thickness)
Is this the best quality I can achieve with this printer, or is there a way to get better quality with different settings?
Welcome!! That is probably the best you will get printing in that orientation.. You could put it at a 45° angle.. This will generate a ton of support on the back but the face will have a lot more detail..
Interesting. Why 45 degrees and not 90? Printing it upright would probably need a thicker bottom plate but much less support (45 degrees support minimum should be given IMHO). And I think it would result in 100% Z accuracy wheras a 45 degrees would be less (half).
So what’s the trick with the 45 degrees I probably missed something?
It looks to be pretty thin.. and round.. If printed at 90° i was thinking the bottom round might look worse than at 45..
No problem.. Now to design the parts around the printer.. lol I try to design my stuff as printer friendly as possible.. Makes it more of a challenge. :D
