Has anyone tried printing with Z-PETG?, my experience so far has been very similar to the one with Z-Glass, very unreliable. Every time I tried it the extruder clogs in the very beginning or by the middle of the print.
The only successful prints I had with Z-GLASS were in shell mode or very thin walled objects and when the print is almost continuous without much extruder travel (not printing).
Yes, this is a bad filament to print with. Default settings in Z-Suite manifests a stringy and blobby print result, which is just not fit for purpose!
It appears that the filament does not flow as well as the Z-Ultrat.
I have also noticed a popping noise, which is probably trapped air in the nozzle caused by to much retraction. What follows is a stringy and blobby output which can be compounded when the hot end decides to move to the opposite end of the job collecting aforementioned blob on the hot end, creating more strings on the print. Perhaps a small tweak in the code to allow the Z-axis to lower 1mm will allow more clearance to prevent this.
In my opinion the printing parameters for this material requires dramatic optimisation from the Zortrax team. I live in hope that a fix for this will become available in the near future.............
