Hi all.
First sorry if my question is stupid.
I just want to print my first project for testing #d Printer M200.
I opened LDView STL sample project with simple gear I found (before.jpg).
After clicking “print” I can see that my object looks different (after.jpg)
Can you tell me “why” ?
I would think the mesh has errors like inverted normals or whatever that made the slicer throw up.
There are quite a lot of free offline tools like Meshmixer and online services to get STL files fixed for 3D printing.
If you google for "repair stl" you'll find dozens of guides.
Andy_B
Try it through Microsoft Model Repair Service: https://tools3d.azurewebsites.net/
hey marcin.kasinski
Looks like an lego technic part :)
Do you fixed the error on slicing this part?
Marcin
5
Crosssections are not joined, I suppose.
I bet if you would load it into NetFabb it would look similar to attached photo. (Z-Suite will create a hole inside model)
Do you use NetFabb or other repair services generally before printing the models?
Marcin
7
Only if I see something strange in Z-Suite or final print itself.
I mostly use NetFabb, sometimes MakePrintable.com
Kyle
8
I believe you are correct. I have found that if I have 2 solids in the same space, it deletes the overlap. It should be one solid part.
ZX81
9
what version exactly (free or with costs?)
Marcin
10
I use the newest one (Autodesk Netfabb). For my purposes - trial is more than enough.
