Is it possible to keep and use two versions of Z-Suite ? I would like to test Z-Suite 2.1 Beta and continue to use Z-Suite 1,12 on the same PC. How to do ? thanks for the answers
im work on win 10 x64 - Im install 1.7.1 to Program Files (x86) and beta to Program Files and booth work ok. But install 1.7.1 first
Thank you for the answer.
I work on Win 7 pro
You installed the 2 versions in 2 separate folders ?
In your PC, Z-Suite Beta does not overwrite the other version ?
I also have 2 versions: 1.12 and 2.1, while installation change folder name (f.e. from Zortrax to Zortax_2-1),
no conflicts,
the only thing is to make 2 shortcuts because only one of them is default program to open files
