Z-Suite 2.11.1.0 - Uneven layer infill and 1st Layer density not changing
Changing the 1st layer density has no visual effect
With round objects, the top and bottom layer density is inconsistent. Square objects are fine.
It is easier if you slice a cylinder and a cube and go through the layers to see the differences.
Thank you for your feedback. Do you possibly have some pictures illustrating the issue? Also, a model would be useful so we could see all applied settings, material type etc.
Here are a picture of supposed 50% first layer density and the uneven density on a disc.
Here is the zprojx so you can test for yourself.
Part1.zprojx (301.8 KB)
Thank you, we will look into that.
