We’ve just released new Z-SUITE 2.12.0 version. Here is the full changelog:
M Series Plus, M300 Dual, Inventure:
- Introduced the new Contour-infill gap option – you can now change the space that is between outer contours of a model and outer contours of infill
Inkspire:
- Improved default support settings – adhesion between models and support has been increased
All devices:
You can download Z-SUITE 2.12.1 here.
Hi Karolina,
Could you explain more about the Contour-infill Gap option?
Contour-infill Gap allows users to change the space between outer contours of a model and outer contours of infill, and thanks to that, make bonding between outer walls and infill stronger.
Hi, I’ve made some tests with the Contour-infill gap. What I see is that by incrementing the value, the gap between external walls and internal walls increases. So how can the bonding be stronger?
I can imagine that the parameter should be decreased to get stronger bonding, is that correct?
In that case, it is not preferable to have this parameter set to zero?
Thank you.
Regards,
Gabriele.
Hi Gabriele,
Please, refer to our troubleshooting manual. In order to make the bonding stronger - you need to decrease the contour-infill gap to 0.0 (the default value is 0.4).
