Z-SUITE 2.20.0 released
We released Z-SUITE 2.20.0. Here is the full changelog:
  • Added Zortrax Endureal to the list of supported devices. The available printing profiles include:
    Z-ULTRAT Plus (single mode and dual mode with Z-SUPPORT ATP),
    Z-PEI 9085 (single mode and dual mode with Z-SUPPORT High-Temp),
    Z-PEI 1010 (dual mode with Z-SUPPORT High-Temp),
    External materials selection based on the main profiles.
  • Introduced .ply as a new input file format (all printers),
  • Introduced a new shape for the Cooling and Waste Towers, which provides better stability when printing high models (M Plus Series and M300 Dual),
  • Added new printing profiles (Zortrax Inventure):
    Z-ABS 0.30 mm (single-extrusion mode),
  • Added new printing profiles (M300 Dual):
    Z-PETG 0.30 and 0.40 mm for 0.6 mm nozzle (single-extrusion mode),
    Z-ABS + Z-SUPPORT ATP 0.30, 0.40 and 0.50 mm for 0.6 mm nozzle,
    Z-HIPS 0.30, 0.40 and 0.50 mm for 0.6 mm nozzle (single-extrusion mode).
Bug fixes:
  • Fixed some cases where models would be repaired incorrectly,
  • Overall performance improvements,
  • Improved printing quality of printing profiles for:
    Z-ULTRAT Plus + Z-SUPPORT ATP 0.15 mm for M300 Dual,
    Z-ASA Pro 0.15 mm in single-extrusion mode for M300 Dual and Zortrax Inventure.
As of the release of Z-SUITE 2.20.0, we’ve decided to focus on improving operation of the program on the newest macOS Big Sur system. As a result, Z-SUITE for OS X El Capitan and macOS Sierra won’t be supported any longer.
We encourage you to install the update and provide your feedback.
You can download Z-SUITE here.
