Since updating Z-Suite to 2.30.0.0 it forgets the default printer saved in the preferences. I had it set to M200 Plus, but now it is None. I can set it again to M200 Plus and save the configuration, but after restarting Z-Suite the default printer is again set to None.
Hello Joelk,
What operating system are you using, and which version?
I’m using Win 10 Enterprise Ver 21H1. Some other parameters I’ve tried to change (e.g. Z-Suite folder location, remember management method choice, export the report to a .txt file) remain unchanged after save->close Z-suite->open Z-suite->File->Preferences, but the Default Printer always gets changed to None.
Rgdz
Joel
Hello Joelk,
Thank you for pointing it out, we are already working on this issue.
Hello Yannick,
Does the error persist?
Are you able to recreate the error and list all the steps you did?
What Z-Suite version were you using before, also which system version are you using?
You can try renaming Zortrax directory “C:\Users\XXX\AppData\Roaming\Zortrax”
Same here, installed previous version.
