Hi, I have a M300 (not Plus, not Dual) and when I run Z-SUITE 2.30 for the Zortrax Materials it does not show Z-ABS or Z-ABS 2. However if I select M200 (or also other printers like M300 Plus), it does show those materials. Is that a bug in the SW ? Or is there something technical ? I had thought a M300 was basically a larger M200 ?
Hello stefans,
It’s not a bug, but these materials are more prone to warping with the bigger platform.
However you can still print with Z-ABS/ABS-2 by using the External Materials → ABS-Based Filament - it’s basically a profile for this material by default that can be tweaked.
