Z-SUITE 2.5.0 released!
Hi guys!
We've just released Z-SUITE 2.5.0.0. and Z-SUITE 2.5.0.0 BETA (for Mac), which:
  • For Windows OS it introduces new features of the program’s GUI - new intuitive design with new colors and new title bar which ensures easier minimizing and maximizing of the program’s window
  • Adds support for the Zortrax M200 Plus
- Adds support for Z-SEMIFLEX (M200 Plus)
  • Introduces the new extended .zcodex format compatible with the M200 Plus
  • Improves exporting of .zcode/.zcodex files in the Preview step - you can either save the file on the USB flash drive or transfer the file directly to M200 Plus over Wi-Fi
  • Introduces new My Devices panel which allows you to:
  • search for and add M200 Plus printers available in the local network to the panel
  • manage the already added printer(s) - you can start and stop the print; change the name of your printer; preview basic information about the printer
  • see the current state of the printer(s): Ready to Print / Printing / Paused / Offline,
  • see which material is loaded in the printer(s) - Last used material
  • add, download and remove .zcodex files from the printer’s USB flash drive
  • display the preview from the printer’s camera
  • Adds the Cross Section View tool - it is possible to see what the inside of the model looks like in the Model, Analysis and Support steps
  • Improves the Split menu - the cutting plane is now more visible
  • Introduces the new keyboard shortcut - CTRL + A - which allows you to select all generated support structures in the Support step and edit them altogether
  • Fixes other minor bugs.
As always, it's available through autoupdater or in our Support Center: https://support.zortrax.com/downloads/software/.
Thank you for the title bar. I will now use the software.
Still doesn't work with OSX 10.11 (El Capitan) though, eh? Is that something that is being worked on, or no?
A lot of new Features ..... ONLY for M200 Plus :-(
We need an export and import function (or backup / restore) for a created print profile (also for foreign material), because a necessary reinstallation I have to enter all settings and profiles again. With an ex / import or backup / restore function it would be much more user-friendly ;-)
Nice! Still waiting for wall thickness adjustments though. :)
Hi Korni!
Your profiles should be still there after doing an update of the Z-SUITE.
Anyway, you can also copy them as text files from this catalogue:
 C:\Users\User\AppData\Roaming\Zortrax\Profiles
Hi I thought this update was meant to fix the text issues introduced in the last update? I still can't read some of the settings...
Hi Korni!
Sorry I am Mac User ...
And in the Mac profile (/Applications/Z-Suite.app/Contents/MonoBundle/Profiles) ONLY the default profiles are stored, but NOT the self-created :frowning:
That's the app bundle you're looking in. I don't use Z-Suite on Mac, but wouldn't your profiles be more likely to be in ~/Library/Application Support/Zortrax, or something like that?
Apparently on the Mac the user profiles are in ~/.config/Zortrax/Profiles/
You normally would expect them indeed in "Application Support"
It's been fixed.
If you still ecnounter the problems, please delete the AppSettings.txt file from the catalogue : AppData -> ... -> Zortrax
It's been fixed.
Huh... thanks for the heads up. I had raised this issue several times before but this is the first I've heard about this fix.
